Archicad C++ API
how to change the contour of a curtain wall?
like the Subject
5 REPLIES 5
like this
David Maudlin
Arthas Wang:
One way is to view the Curtain Wall (CW) in elevation, select it, click the Edit button, make the Scheme Grid visible (it may be helpful to make the other elements not visible), a heavy boundary will appear that can be edited with the Pet Palette similar to a Fill.
There is an older method using the Extract Boundary to Fill command.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thanks David, sorry I didn't make it clear, i was going to ask how to change the contour by API, like where to change the parameters and how to set masks or memo masks to 'ACAPI_Elemeng_Change' it. thanks again
David Maudlin
Arthas:
Oops, my mistake, I did not notice that this is in the developer forum. I hope someone else can help.
David
thanks anyway
