2018-12-27
03:20 AM
- last edited on
2022-10-04
04:46 PM
by
Daniel Kassai
void Do_CurtainWall_createAccessory(void)
API_Element element, mask;
API_LibPart libPart;
API_Guid guid, guid1,guid2;
API_ElemTypeID typeID;
GSErrCode err;
BNZeroMemory(&element, sizeof(API_Element));
if (!ClickAnElem("Click a Curtain Wall to Modify", API_CurtainWallFrameID, nullptr, &typeID, &guid)) {
WriteReport_Alert("No curtain wall was clicked");
return;
element.header.guid = guid;
element.header.typeID = typeID;
err = ACAPI_Element_Get(&element);
guid2=element.cwFrame.symbolID;
guid1 = element.cwFrame.owner;
////return index///
BNZeroMemory(&libPart, sizeof(libPart));
GS::snuprintf(libPart.docu_UName, sizeof(libPart.docu_UName) / sizeof(GS::uchar_t), L("D-T吊件"));
err = ACAPI_LibPart_Search(&libPart, false);
if (err != NoError)
return;
int indac = libPart.index;
// element.header.typeID = API_CurtainWallAccessoryID;
element.cwAccessory.head.typeID = API_CurtainWallAccessoryID;
err = ACAPI_Element_GetDefaults(&element, nullptr);
if (err != NoError) {
ErrorBeep("ACAPI_Element_GetDefaults", err);
return;
element.cwAccessory.refFrame = guid;
//element.cwAccessory.category = APICWAccC_Custom;
element.cwAccessory.owner = guid1;
//element.cwAccessory.hasSymbol = true;
//element.cwAccessory.symbolID = guid2;
//element.cwAccessory.libInd = indac;
err = ACAPI_Element_Create(&element, nullptr);
// ACAPI_DisposeElemMemoHdls(&memo);
hello everyone!2018-12-27 02:59 PM
2018-12-29 02:38 AM
Tibor wrote:Hi Tibor!
Creating new curtain wall subelem (frame, panel, accessory, junction) is not available via API using the ACAPI_Element_Create or ACAPI_Element_CreateExt functions.
You can add only new frames to an existing curtain wall by using the ACAPI_Element_Change on the curtain wall and passing the new frames in the cWallFrames field of the memo.
2019-01-10 04:20 PM
vanxis wrote:Sorry if I was not clear enough.
I don't know how I need to enter parameters in memo if I want to create a accessory or a juction.
2019-01-11 02:45 AM
Tibor wrote:I'm sorry to hear that. I can only find another way. thanks !
You can add only new frames to an existing curtain wall via API.
Currently there is no way to create new accessories or junctions using the API.
