ā2019-10-11
08:27 AM
ā2022-09-29
10:08 AM
Daniel Kassai
Solved! Go to Solution.
ā2019-10-11 10:56 AM
API_StoryInfo storyInfo; BNZeroMemory(& storyInfo, sizeof (API_StoryInfo)); GSErrCode err = ACAPI_Environment(APIEnv_GetStorySettingsID, &storyInfo, nullptr); //ā¦get whatever you need from the story data BMKillHandle((GSHandle *) &storyInfo.data);The
ā2019-10-11 10:19 AM
ā2019-10-11 10:25 AM
Ralph wrote:yes.
Sorry, I'm not clear on the question. Do you want the building storey information, e.g. the name, base level and height of each floor in the building?
ā2019-10-11 01:14 PM
ā2019-10-11 02:25 PM
ā2019-10-12 02:45 AM
Ralph wrote:except IFCļ¼is there the "Building" concept in Archicadļ¼
When you say "Building", do you mean as defined by IFC?
ā2019-10-12 10:56 AM
ā2019-10-14 05:04 AM
Ralph wrote:Thank you very much. I understand it.
The ARCHICAD API doesn't really define the concept of a 'building' apart from IFC. We've had to rely on geometric methods to discover the perimeter of a building within a project and then allocate elements to buildings on the basis of containment.
The API doesn't have a formal concept of a database either, at least not in the conventional sense. A database is loosely a collection of homogenous data structures, e.g. all attributes or all elements.
Most API calls don' reference a database ā the ones that do are mostly found in the documentation forACAPI_Database, e.g. APIDb_ChangeCurrentDatabaseID(which changes the active database). Once a database is 'set', other API calls act on that database, e.g. ACAPI_Element_Getto retrieve a specific element.
The element data structure is API_Element. You can determine which floor an element belongs to by inspecting its header,header.floorInd. The details of the floor can be retrieved using the method I described above with APIEnv_GetStorySettingsID.
