LeeJaeYoung
is it possible to work on the Archicad 26 trial version?
I'm trying to study API at archicad 26.
1. Is it possible to write with visual studio 2019 community?
2. Since I am studying personally, is it possible to work on the Archicad 26 trial version?
3.Can I download this and use it?
AC27 on window 11
5 Replies 5
1. Yes this works. I'm using Visual Studio 2022 community, but 2019 should also work.
2. I started out using the Archicad 24 Trial Version. So I assume it's possible to also use the Archicad 26 Trial Version now.
3. Maybe it's better to get the x64 version.
Automating Archicad with Add-Ons, GDL-Objects & Python Archi-XT.com
LeeJaeYoung
I've never used x64. Are there any advantages?
AC27 on window 11
You are running Windows 11 which only comes as an x64 version I think. When you use x64 versions of programs, then you skip the WoW 64 translation layer. In practice it probably doesn't make much difference for AC Add-On development.
LeeJaeYoung
However, in the trial version, you cannot study GDL. How can it be done?
AC27 on window 11
Isn't the trial version fully featured but only available for 1 month?
I think you mean the DEMO version maybe?
You can use the LP_XMLConverter as a workaround.
Check the help for it in e.g. PowerShell (adapt the path according to your installation):
& "C:/Program Files/GRAPHISOFT/Archicad 26/LP_XMLConverter.exe" help
Here's a more detailed workflow:
1. Pick a .gsm file from somewhere and run:
> & "C:/Program Files/GRAPHISOFT/Archicad 26/LP_XMLConverter.exe" libpart2hsf test.gsm test/​
2. You have a folder with .xml and .gdl scripts now. Change them to your needs.
3. Convert back to a .gsm file:
> & "C:/Program Files/GRAPHISOFT/Archicad 26/LP_XMLConverter.exe" hsf2libpart test/ test.gsm
