problem with add-on running in x64 bit ArchiCAD
I compiled my addon that can run in archicad13, 32 bit, pc.
I open up a new API project with "include x64 target" option checked and transfer all the script across and compile it again.
When I try to load the add on under window 7, archicad13, 64 bit. It says:
"The file is an outdated Add-On that cannot be used with this Archicad.exe"
What can I do to make the add on run in archicad13, 64 bit window 7?
I am using visualstudio 2005 as my development platform
Thanks
Alfred
sorted with setting active solution platform to x64 in vs2005. Thanks
