2011-06-12
03:30 PM
2023-08-03
09:48 AM
Doreena Deng
2011-06-12 05:10 PM
2011-06-12 09:00 PM
zanzibar wrote:Does this error occur when you run ArchiCAD in demo mode too? And which compiler are you using to build the add-on?
"the file is an outdated add-on that cannot be used with this archicad version"
2011-06-13 08:14 AM
2011-06-13 09:53 AM
zanzibar wrote:I suppose I should ask the other obvious questions. Are you using the ArchiCAD 13 devkit? Note that devkits for one version of ArchiCAD are not compatible with another.
Yes. Iv'e tried this in demo mode only...
And I'm using VS2005.
2011-06-13 10:19 AM
correct word size for your target OSAnd yeah, I tried it several times : compiled as 64 bit in 64 bit O.S, and tried running it in a 64 bit AC13 (btw the devkit should be suitable).
2011-06-13 10:48 AM
zanzibar wrote:'Word size' refers to the number of bits in the 'natural' unit of data for the target. This is typically the size of a memory address for the target.
Didnt understand what you mean by that:correct word size for your target OSAnd yeah, I tried it several times : compiled as 64 bit in 64 bit O.S, and tried running it in a 64 bit AC13 (btw the devkit should be suitable).
2011-06-13 11:12 AM
2011-06-13 03:38 PM
zanzibar wrote:I'm baffled. Try cleaning the project and then rebuilding. Does the add-on appear to build without error? In particular, are the resources compiled correctly? Check that the GRC compiler output is present and correct. It might be worth check all the project paths too - perhaps the project is linking against the wrong libraries.
Exactly. Iv'e done that several times and it didnt work.
2011-06-13 04:36 PM
