_hque
ArchiCAD API / ArchiCAD JSON API
Hi everybody,
I have a web app with my own way to structure a building's data and geometry and I want to export it to ArchiCAD.
So creating an ArchiCAD file with all elements (walls, slabs, ...) as ArchiCAD objects and download it.
Is it possible to have this custom export script on a Web API using the ArchiCAD JSON API or is there another way to achieve this?
Best,
Niklas
4 Replies 4
Joel Buehler
i hope i understand you question right, but from waht i get, you want to use the ArchiCAD JSON API to get information out of Archicad, right?
That does not work with the JSON Interface, since this is a oneway communication.
https://archicadapi.graphisoft.com/JSONInterfaceDocumentation/#Introduction
but no problem! you can just write your own plugin that has that functionality with the Archicad API.
EDIT: i should have first read the documentation 😄
you can get a lot of information trough the API. like this example:
https://archicadapi.graphisoft.com/JSONInterfaceDocumentation/#GetPropertyIds
very cool.
_hque
Thanks for your answer @Joel Buehler
hm, not really I want to create more or less an "Export to ArchiCAD" for my custom logic of geometry and building elements. So it would be rather information to ArchiCAD.
All the examples that I found using the ArchiCAD JSON API is getting information from an ArchiCAD file like in your posted example getting properties from a file.
Joel Buehler
Ah oh, ok now i get you. thats sounds interesting!
kency
You can write your own Archicad Add-On, invoke API to get the data and will be able to create walls, slabs, morphs  etc. https://graphisoft.github.io/archicad-api-devkit/index.html.
This can be a starter https://github.com/GRAPHISOFT/archicad-maze-generator?tab=readme-ov-file
