Objects to position according to coordinate list
Actually I have a list of coordinates (in a text/csv/excel file), and I have to position object elements (800 pcs) to the coordinates in the list.
I thought that a python script could do this. I tried with the excel export/import script.
But as far as I can see: with this method I can adjust almost every property, but of the object coordinates.
I need help to solve this issue.
I'm not addicted to the python method, any other solution would be welcomed.
14 Replies 14
kuvbur
If I understood you correctly,
SomeStuff add-on can write property values directly into an element's ID field using its Sync_to{ID} command.
I've updated the example file to demonstrate this specific functionality. You can download the latest version to see how Sync_to{ID} works in practice
Industrial Architect and Structural Design Engineer, developer of free addon for sync GDL param and properties
Works perfectly.
Thanks!!
Can I find the possible other parameters/fields to sync, somewhere?
Dear Berndt & runxel & Mathias,
Thanks for the info about tapir - it will help a lot later. A long time ago I wanted to try it out - but I thought it is much more complicated; now I know it's not. Your quick & concise answers really helped me.
kuvbur
Yes, of course. Automatically translated help for commands is here
Ben D
Hi Dmitry,
I am also trying to set the ID, position and size of a large number of objects from data in an excel spreadsheet.  This looks like the perfect solution - but the example file linked is no longer available.  could you put one up again showing how to do this? (ideally in AC28)
Thanks
Ben
BIM Manager / Senior Designer @ Neeson Murcutt Neille, Sydney Australia
AC28 AUS + CI Tools, BIMcloud SaaS
Apple Mac Studio CPU: M1 Ultra 20C GPU:48C RAM:64GB OS:Sequoia 15.7.5
PC CPU: Ryzen 9 7950X GPU:RTX4080 RAM:64GB OS:Win11
