[PYTHON] Sum area script
Hi everybody!
I developped a python script that sum the zone area  with the help of Poco.
The script sum all zone of the same zone number and put the result in a custom property. You just have to retrieve the value with a label (example file in the zip).
The custom property has to be to string type.
The scrip uses the measured area.
Archicad 27 - GDL - PYTHON
25 Replies 25
Gaberic
Dear Jonathan,
Thank you for this script which solve a big loophole in the whole zones system,
one rather dumb question : I can't seem to find the way to run your python script from the TAPIR addon/palette I have installed following your advice. I am most likely missing something obvious - could you quickly explain the steps to do so ?
Thank you,
c
pr3
Hello Jonathan,
The Script is perfekt for us - we use it for multiple Projects and really like it. the New version increased the usability ever further.
I Would like to point a problem that Archicad has for decades - the Sum of Areas in an interactive schedule differs from the Sum the archicad built in system or your script gives us.
Thats clearly a rounding error but for some of our customers it's crucial that the sums are exactly the same. The error is in the 2 digit after the comma.
Are you aware of this and do you see a way to compensate or even solve this issue?
Archicad 28 | Mac Studio | OS 26
Hi pr3 !
I'm well aware of this issue, this is the reason why there is a "Value type" parameter now:
-Displayed Area or Measured Area
Did you try this parameter? It is possible that there is a bug because I only use the Displayed Value area. If there is still an error, i'll investigate this.
@Gaberic Where is the problem exactly? Is the script loaded in the Tapir palette?
I have not studied the script, so I can't say how the totals are calculated there.
But in the schedules you do have an option.
Actually the setting is found in Project Preferences > Calculation Rules
It can total the exact figures you see in the schedule, or the real un-rounded figures that you don't see.
pr3
Barry this is it - thank you so much.
