Archicad Python API
About automating tasks in Archicad using the Python API.
Parameters for GetAttributesByType("..."))
smathiebe
Hi All,
I just startet using python with Archicad. The documentation is a bit confusing.
Where can I find the possible paramters for GetAttributesByType.
I found the example with GetAttributesByType("LayerCombination")) but which other types are possible?
Thanks in advance
Stefan
AC25-28, Win10
poco2013
Mentor
Available attributes are: Composite, Fill, Layer, LayerCombination, Line, PenTable, Profile, Surface, ZoneCategory -- Building Material has its own function. You can see all the available types in the class definition in  the Python Archicad 'site-packages folder
Gerry
1 REPLY 1
poco2013
Mentor
Gerry
