We value your input!
Archicad Python API
About automating tasks in Archicad using the Python API.
Restore "Link to Default" property values by Python
_c_
I am trying to set elements' values to their defaults: be it undefined, expression, or value. Whatever is in the Attribute Manager for the property definition. For clarifying, by default will look like this upon selection:
default undefined value default defined value default expression
There is no direct access in the JSON API, but I found a trick to determine if a property is defined by expression: they DON'T have a "defaultValue" dict key.
It seems nevertheless to be impossible to actually SET the property value to "Link to Default". Whenever I copy the defaults from the property definition into the element's value this turns into "custom".
Does anyone know a trick?
_c_
1 REPLY 1
_c_
I'd like to put this thread into the praxis context it came from.
I was working on a door list with odd 1800 items when I realised that a large number of elements had an override of "from/to room number" calculated properties into a fixed custom value. It came from ill prepared favourites.
This could have been a fatal error.
It is important to fish out elements whose calculations are overridden and possibly set them by script.
_c_
