BIMX Corrupt - ArchiCad 17 Windows 7
Marquee on plan > F5 (3D View) > File > Save As - Bimx
When open in BIMX viewer, the view position is fixed with only zoom and rotation of model active. No fly, up, down, directional arrows. All options (Esc) available.
Not a driver issue as BIMX works fine on earlier saves and in other projects. Last action with possible cause for issue - generic axonometric view changed OpenGL to Internal Engine. 3D window setting for save as bimx is set to OpenGL (std).
This has happened before and to resolve, I had to migrate the whole project to a new template.
Problem BIMX here: https://dl.dropboxusercontent.com/u/14279669/SMITH%20DA%2013.bimx
Thanks
Reto
Hey Reto,
In BIMx try pressing the F8 key to change the view - it is a toggle switch.
Press it once lets you explore the model and again to only spin it around.
Hi Baz, thanks again. So simple. F8 .... lol
