yesterday
Hi all,
We work in Teamwork on BIMcloud (Archicad 28) with several users in the same project. As BIM Manager I need a reliable, automatic record of WHO did WHAT to each element and WHEN.
What I'm looking for:
1. Automatic stamping on the element itself
Every time an element is created, reserved or modified, a custom property (e.g. "EditedBy") should be filled automatically with:
- Teamwork user name (or initials)
- Date and time
- Action: Created / Reserved / Modified / Released
Ideally it keeps a short history (e.g. last 3–5 entries) and/or separate fields like "CreatedBy" and "LastEditedBy", so we can use them in schedules, labels and Graphic Overrides.
2. A persistent reservation/edit log
A log outside the model (CSV/Excel on a shared drive is fine) recording every reservation, release and Send & Receive per element:
Date/time | User | Element GUID | Element ID | Element type | Action
3. It must be automatic
No manual input from users and no scripts they need to remember to run – it should happen in the background on reserve, release or Send & Receive.
What I've already checked:
- Change Tracking (AC24+): useful for notifications, but the Tracked Changes list is cleared after receiving changes, only shows the latest change, and is per user. It's not a persistent history and isn't stored on the elements.
- Reservation info / Info Tag / colored workspaces: only show the CURRENT owner, not who created or previously edited an element.
- Expression properties can't read the Teamwork user name.
- Favorites with a preset "CreatedBy" value: works partly, but relies on users always placing from Favorites and doesn't capture later edits.
- Python / JSON API: as far as I can tell, it can't react to reservation events and has to be run manually by each user.
- Older thread asking for a similar "who did this?" feature (2020), with no solution at the time: https://community.graphisoft.com/t5/Project-data-BIM/History-of-element/td-p/221385
My questions:
1. Is there an existing add-on (free or commercial) that does this, or anything close?
2. Has anyone built something similar with the C++ API (e.g. catching element reservation-change notifications and writing the user name into a property or log file)? Any pitfalls with Teamwork, for example writing to elements just before release?
3. Is anything like this planned by Graphisoft, or should I post it on the Wishlist?
Any advice, existing tools or workflows would be much appreciated. Thanks!
AC28 28.4.0 (7006) UKI FULL (from AC13)
HP ZBook X G1i 16" Intel Core Ultra 7 255H, 32GB RAM, NVIDIA RTX PRO 1000 Blackwell 8GB, 1TB SSD, Windows 11 Pro (Build 26300)
MacBook Pro M1 Max 14.2", 10-core CPU, 64GB RAM, 32-core GPU, 1TB SSD, MacOS Ventura 13.6.2
Self-guided, shape it until it shifts.
5 hours ago
I do not think any such item exists on the Roadmap, so if your don't get any answers that such an Add-On already exists, then posting a wish is the way to go.
