Martins Valters
BIMx sign-in fails on iPadOS 16 due to untrusted Graphisoft certificate
I am unable to sign in to BIMx on an older iPad Pro, although the installed operating system still meets the published minimum BIMx system requirements.
Device and software:
  • Device: iPad Pro 12.9-inch, model ML2J2HC/A
  • Operating system: iPadOS 16.7.16
  • BIMx version: 2026.6910
  • Internet connection: Personal Hotspot from an iPhone
Problem:
When I select “Sign in with Graphisoft ID” in BIMx, the following message appears:
“Sign-in failed. Something went wrong during sign-in. Sorry for the inconvenience. Please try again later.”
I then tested the ID login directly in Safari on the same iPad. The login process redirects to "idproxy graphisoft com", where Safari displays:
“This Connection Is Not Private.”
Certificate information shown on the iPad:
  • Issued to: *.graphisoft com
  • Issued by: Sectigo Public Server Authentication CA DV R 36
  • Status: Not Trusted
  • Expiry date: 31 October 2026
0 Replies 0
