2024-08-28 08:27 PM
I can't manage to show in BIMx Element Info MEP data, only MEP system and Element Id, I would need diameter and dimensions, is it possible ? Thank you very much
Solved! Go to Solution.
a month ago
Try to make a schedule with the properties you want to export with the BIMx and choose it as scheme in the export dialog
a month ago
