Multiple views per layout using Autosplit
Hello Brains Trust!
Is there a way to have more than one view per sheet using the auto-split (split drawing among multiple layouts)
My door type schedule, on an A1 sheet can accommodate 3 rows of the schedule - but I can't seem to add a new view (row) to the page other than a duplicate of the existing view.
i could do it all manually but then you lose the automatic finish and start co-ordination - which I like a great deal.
any ideas?
9 REPLIES 9
...Always with the hard questions!!
Guess the answer is 'No.'.
It seems not.
You can restructure the table to manually spread it across the page which then wraps the schedule to fit the space you choose.
But if your schedule is still larger than the page you must duplicate it manually as you say and crop each drawing to show what you want.
As soon as you choose the option to "split among layouts" it converts the schedule back to a single row (or column) and then distributes that among the required number of new layout pages.
I would consider this a bug as I think it is not working as it should.
Some images for an explaination.
Restructuring the table.
Splitting among layouts.
Thanks Barry!
You illustrated the issue well.
I have not tried this in 16 yet but gather it's the same.
thanks for the attention - feel less solitary!
That was 16 that I tried it in.
nitizz
so all the split layouts keep same drawing number when you press next page?
how to make it sequence?
AC27 INT FULL
27-inch 2019 iMac Retina 5K 10.14.6 macOS Mojave
3.6 GHz Core I9 Radeon Pro 580X 8GB
www.rethinkstudio.mu
So this annoyance is the same in 17 as far as I can tell as well. . .
davidstonearchicad21
This issue persists in AC21!
7 windows per A1 sheet, 18 A1 layouts
The trees are forming a union!
AC24
2 x Xeon E5-2667 v2 (16c/32t @ 3.3-4.0 GHz)
64Gb RAM(ECC) Quad channel 1333Ghz (next upgrade 1866Ghz)
Nvidia GeForce GTX 1080 Ti 11Gb
500Gb 840PRO SSD, 3 TB HDD (next upgrade PCIe NVMe SSD)
