3d Topo surveys into ArchiCad
We get our surveys in 3D AutoCad. Is there a way to import the file and preserve the "Z" coordinates?
6 Replies 6
Andy Thomson
Mentor
Import block as library object?
Andy Thomson, M.Arch, OAA, MRAIC
Director
Thomson Architecture, Inc.
Instructor/Lecturer, Toronto Metropolitan University Faculty of Engineering & Architectural Science
AC26/iMacPro/MPB Silicon M2Pro
I believe ArchiTerra can do that for you.
Djordje
ArchiTerra will open the 3D and create a topo mesh on top.
Check it out - it works.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
only works with DXF files though...
We're getting DWGs coming through the door and have no way of bringing them into AC...
I'm not at work at the moment so can't test, but this software might work for converting your dwgs:
http://anydwg.com/dwg-dxf/?gclid=CJvH6sOn444CFRZZYQod4kQXSQ
or, not free but this:
http://www.autodwg.com/DWG_DXF_Converter/
Djordje
For the conversion, use True DWG Convert. Free download from Autodesk web site
Djordje
HP Omen
