3d Wind design software compatable with archicad
Is there any software that will calculate the wind loads on a building from a archicad 3d model.
With the "new" residential wind codes This would be incredibly helpful if you could see the forces that need to be resisted at the corners or shear in a wall etc.
Maybe something similar to ecodesigner addon or another type software that can import an ifc.
1 REPLY 1
Nemetschek Scia is a FEA structural system that can import IFC files and has a wind load generator.
