3ds in conversion error AC15
Hi all,
I'm having trouble converting 3ds objects to GDL using the 3D STUDIO IN add-on. The converter is not bring in any data, all it does to a converted object is create hotspots, otherwise the object is empty.
I used this tool about 6 months ago and it worked fine so I went back to that project file to try again with the same 3ds object i used back then and this time the conversion no longer works.
I've reinstalled the 3D STUDIO IN add-on and reinstalled AC15 hotfix #4 but it's still not working.
I'm not sure what my archicad build number was the last time i successfully used the converter, but I would like to try it out on older builds, perhaps hotfix #3, is there a way to uninstall hotfixes or rollback to a previous build?
Thanks, Nick
Running AC15 AUS, latest build
0 Replies 0
