I have been trying to put a current project model into GE.
A fairly simple block of apartments but heavily detailed.
So I have made a stripped down, racing copy with all the non essential elements stripped out and many of the remaining layers closed off.
All that is effectively left are the external walls, major floor slabs and the roof constructions.
The AC11 to SKP to 3DW system seems to work but after 20 minutes of file rebuilding and transmission, all I get is a one line error message that the file size has to be less than 10Mb.
No indication as to whether this is still 100Mb, or 10.1Mb.
It is not a major project and therefore it opens the question, if GS have gone to the trouble to implement the interface, how come it is effectively unusable for even a modest project?
The polycount is now less than 40k, having started at over 200k and is devoid of internal fittings, doors and plumbing. Nothing more to remove other than the shell itself.
So, suggestions on how to make this functional, please.
Also, is there any way to determine the actual failed file size at 3DW?
Lastly, is there any way to export the AC11 directly to SKP, so it can be modified in SU or simply emailed to a client without using 3DW?
