Rok Benda
AC28 – DWG Export with Survey Point Error
Hello,
When exporting a geolocated DWG using the Survey Point function, the inserted survey plan (as an Xref) is scaled down by a factor of 1000. The Archicad drawing itself is correctly located. If you insert the survey file directly into Autocad, it is positioned correctly also. The issue only occurs when inserting the Xref in version 28. For projects that were started in previous versions, the export works correctly even in AC28.
Has anyone encountered this issue or found a solution?
Thank you and best regards,
Rok
P.S. This is not a unit conversion issue (m/mm). I’ve checked all of that 🙂
Operating system used: Windows 10 Home
0 Replies 0
