Adding Units to Zone Schedule Value Measured Area
I'm trying to create an area summary of my zones but I can only get the values for the measured areas referenced from the zones to show as a number not a number with units after. For example Site Area 1 is listed as 650 rather than 650m2. When I add the sum of the areas to the bottom it adds the m2 unit but not to the individual values themselves.
I've tried adding in custom text fields but am unable to edit them. Is there a trick to getting this to work?
1 REPLY 1
As you have discovered the units will display only in the totals.
I sometimes add the units to the header text.
