Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
ArchiRotate for all of you...
ArchiRotate
Did you ever need to freely rotate an ArchiCAD library part in 3D space?
With the release of ArchiRotate, any ArchiCAD object can be rotated freely in 3D space - no GDL scripting required! Now, all ArchiCAD users can easily position objects the way they want, quickly achieving their vision.
FREE OF CHARGE from Cigraph Factory!
http://www.cigraph.it/cigraph/pagetrans.do?action=current_product&prodotti_id=26&lang=en
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
19 Replies 19
Rod Jurich
Fabrizio wrote:
ArchiRotate
Many thanks Fabrizio.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
You're welcome Rod.
I just want to take the opportunity to say that, as usual, I decided to keep this first release at a really "low level".
I mean, ArchiRotate is really simple and it doesn't provide the user with a lot of features (just convert the object and let you rotate them).
That means it can be improved but... I preferred to wait for the users input.
Play with it and then send me (privately because this is not the ArchiRotate forum!) any comment, suggestion or wish you think could be important to get a good tool for any ArchiCAD user.
Friendly
Fabrizio
Fabrizio Diodati
Dwight
Thank you, Fabrizio.
Your company has contributed a useful function to Archicad: a basic function we have needed for ever. And for free. Thanks.
Might I suggest that you take on some of the other basic deficiencies in Archicad:
Here are their names:
ArchiDRAFT - okay - done that: ArchiRULER.
ArchiCALCULATE
ArchiRENDER
We often suffer deficiencies believing that they would take lots of Graphisoft resources to remedy. But in many cases, it is not true. Like with your rotate tool. Perhaps Cigraph could redo Archicad entirely, eliminating its deficiencies with one amalgamated utility:
ArchiArchiCAD
That would be worth something - say around the price of an Archicad licensing fee.
Dwight Atkinson
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Dear Dwight,
first of all, do you remember me?
We met each other in Budapest HQ so maybe you think I'm working for Graphisoft!
Please I didn't want to offend you, I was just joking.
ArchiRotate is a very simple add-on so we decided to release it free of charge: who could spend 86 Euro for buying such kind of software?
About the other suggestion, missing function to address, I agree with you but the API environment is not so powerful and it's not so simple to develop anything the users need (and let me say this is a GS task... or it should be!).
On the other hand, I hope nobody misunderstood this "event": we are not going to develop software free of charge.
In any case, I have a good news for you (and the other ArchiCAD users), at least I hope:
ArchiCALCULATE ... already done!
The name will be ArchiQuant (thanks to Karl for the name suggestion!).
But in this case... it won't be free of charge.
Friendly
Fabrizio
P.S. BTW, the same suggestion could also fit to your wonderful LightWork in ArchiCAD manual ... doesn't it should be included as standard manual in the AC manual set? It's the best AC manual I read in the last 15 years.
Fabrizio Diodati
Dwight
Of course i remember you with fondness.
I was joking, too.
The fact that Cigraph can solve a long-term Archicad gripe [rotating an object] makes me cynically joke that perhaps many of the other things users complain about can also be simply fixed, if only Graphisoft would allocate the resources to fix them.
I also do believe that my book exists partly because of deficient Graphisoft rendering documentation - once i saw black soffit disease in user guide images, it was vital to bring better solutions to the users.
But Graphisoft has never [see the GDL reference manual for example] been interested in teaching its product with its manuals. These are separate functions. "What" versus "How."
Best wishes.
Dwight Atkinson
Nuge
Fabrizio,
ArchiRotate is great, the best ideas are always the simple ones.
Can you please give us some more information on "ArchiQuant"
What is it?
How does it work?
Can you show some samples?
Regards Nuge
AC27 i9 14900KF / 128G ram / GTX 5090 / D5 Render
Dwight
I misread that.
I read "ArchiQuaint."
That utility would add diamond pane mullions, scrollwork and bric-a-brac to an otherwise plain structure. It would need a large ArchiDog and a rocking chair for the porch.
Dwight Atkinson
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Hi Nuge,
here is a very short ArchiQuant description.
ArchiQuant is a simple add-on that let’s you get quantity take-offs together with costs estimation.
ArchiCAD already let’s you get something similar (I suggest to every ArchiCAD user to buy the wonderful handbook “ArchiCAD, From CAD to Quantity Survey” by Eric Wilk) but the user has to do a lot of job and he also needs to have some familiarity with GDL commands.
For using the “standard” ArchiCAD quantity calculation procedure you have to do several steps:
1. Built your components database (quite annoying because you cannot import existing external databases)
2. Built your Attribute objects: this needs some GDL expertise because if you need to calculate specific quantities from a construction element you have to use some GDL statement to refer to the right quantity
3. Link the Attribute object to your construction elements
4. Built up your list scheme in order to display these info
The main limitation of all this job, from my point of view, is that isn’t so easy to get quantity take off together with the cost estimation coming from this calculation and, for me as architect (at least here in Italy) this is not enough: I cannot say my client that he needs to buy 100 bricks… he will immediately ask me “how much do they cost?”.
This come from a “strange” GS definition of the component.
For GS a component is essentially made by:
1. an identity code
2. a name/description (limited to just 127 characters)
3. a unit
4. a quantity
The missing items from this definition (once again for me!) are:
5. the currency unit
6. the unit price of the component
ArchiQuant tries to address these issues:
1. You have your quantity database, where you can also import external database or convert your already built ArchiCAD ones.
2. the component elements include also currency unit and unit price info
3. No limitation in the component description (it can be long as you desire)
4. Absolutely no GDL skill (you can define your calculation formula just as you do “by hand” by referring to the element quantities and to any kind of mathematical calculation sums, subtractions, multiplications, divisions, ect.)
5. No needs to create dozen of attribute objects to link the components to the construction elements: just select the construction element and by opening its setting dialog window you will find the ArchiQuant panel where you can link your database components to your selected element/s.
6. You can calculate also the two-dimensional entities
7. you can customize you list schemes (the ArchiQuant list schemes) by using the dedicated setting dialog windows (let me swear it is more comfortable/friendly that the ArchiCAD one)
8. you can always export your quantity/estimation data in a spreadsheet format
9. you can calculate/display quantities together with cost estimation
This is just a “snack” of the ArchiQuant functions.
Now the user manuals are in the translation phase, I think it will be released in the next autumn… to be sure, let me say before Christmas.
Friendly
Fabrizio
Fabrizio Diodati
What can i say.
I super old wish that should have been address by Graphisoft.
This is a MUST HAVE add on.
I also think that archicad needs to spend a version to completely rewrite its code so to enable
1) complete 3d awareness
2) complete super powerfull api
3) complete scripting vb-like langruage.
We can then see some really super powerfull addons.
nice work fabrizio
