Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
ArchiStair is ready!
Dear ArchiCAD users,
finally ArchiStair is ready and… FREE OF CHARGE!
Please get any info at www.archistair.com
Friendly
Fabrizio
In order to get info on the way you can receive your free ArchiStair please directly contact our sales manager sending her an e-mail at [email protected]
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
168 Replies 168
Just to add to my previous post, when I offset the rails, but have them hidden on the floor plan I am able to move between stories and see the stairs wiith no problems. It seems to only have problems when I turn on the stair rails on the floor plan and try to go up or down a story.
Darrel Ebanks
Tropical Home Designs
Cayman Islands
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Thanks a lot Darrel!
You are right: there is a bug in the current version.
I'm going to fix it, tomorrow I will upload the new maintenance update at www.cigraph-store.com
BTW, please, when you find any bug or malfunction, be so kind to directly send me an e-mail: of course I check this forum any day but if you directly write me you will be more sure I get your requests.
Friendly
Fabrizio
Fabrizio Diodati
Wait Fabrizzio, I have next bug - see on the picture.
Pawel
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Thanks!
Fabrizio Diodati
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Thanks Pawel,
I fixed this one also...
Tomorrow I will update this version.
Friendly
Fabrizio
Fabrizio Diodati
Thanks Fabrizio, this is important for me. ArchiSTAIR is great program. Below I add an attachment - stair created by Rafal Slek with suggestion for add enchance curve resolution parameter if it possible.
Best Regards
Pawel
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Dear users,
as promised you, I just upload the latest maintenance release of ArchiStair (ver.1.07).
In order to get it you can go to www.cigraph-store.com or, if you are ArchiCAD 9 users (the ArchiCAD 8.x version of ArchiStair doesn’t provide you with this feature) you can also use the update command from the ArchiStair menu.
In the first case (using www.cigraph-store.com) you will get the whole ArchiStair folder (containing both the add-on and the library and the other stuffs), in the second case (using the ArchiStair update command) you will get only the add-on.
To update you ArchiStair: once you downloaded the maintenance release, delete the previous one and copy this latest one (after you well expanded it!) in the ArchiStair folder.
Let me say a big thanks to Darrel and Pawel for their big help in finding these little (but fastidious!) bugs.
Friendly
Fabrizio
Fabrizio Diodati
Fabrizio, thanks a lot for fix this bugs.
Pawel
You are the best
Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Thanks to you oreopoulos (BTW is oreopoulos your first name?)!
You don't have to thanks for this issues: we are fixing our bugs (that means our "faults") so, probably, we should say thank you for your patience!
BTW, I will write you about the numbering tread orientation issue that isn't so simple (but also not a mission impossible!) so I haven't been able to implement it in this last maintenance update.
Friendly
Fabrizio
Fabrizio Diodati
