‎2003-11-04 11:50 PM
‎2003-11-06 06:23 PM
‎2003-11-06 11:42 PM
‎2003-11-07 02:35 AM
‎2003-11-07 09:14 AM
‎2003-11-07 08:02 PM
Fabrizio wrote:Fabrizio,
No.
At this point I suppose the better solution should be that you sent me your PLN file (with the roads middlelines already inserted) and I will convert them into Road: this only to better understand what is wrong...
Friendly
‎2003-11-08 12:34 AM
‎2003-11-08 12:54 AM
‎2003-11-08 02:56 AM
‎2003-11-08 03:09 AM
"Fabrizio Diodati" wrote:
Dear Jacek,
I'm really sorry but I'm not in the office so I will cehck your file on next Monday morning.
So you started from DXF file: are you sure it contains only 2D info?
Because if it contains 3D polylines (that contains the Z level of the contour lines)
Fabrizio,You are right!
I was able to reduce the original file down to size, at which point ArchiTerra was able to import and convert the data into points!
I tried that several times earlier and the file was allways too large.
I have replied to you privatelyhalf hour ago, so I will post a copy of my earlier letter here:
Fabrizio,
I was able to create the Site model by importing the DXF file into ArchiTerra!
I have attached two renderings of the new model (JPEG Files 1 & 2) and a copy of the 'older' file generated by manually drawing contours and converting them into a terrain. The manual file is so much larger than the other two?
Anyway, I will continue with these files and see how the roads will work with them, perhaps the 2-D information that was part of the tracing process added so much to the file size, and the manual process increases size as well?
Thank you for all your help.
Jacek
I am posting a view of a model sent to you below.
Once again thank you for all your help.
Ciao,
Jacek
‎2003-11-08 12:21 PM
