Archicad 11 to PowerCADD 7 DWG translator
Can anyone help me???
When I save an Archicad 11 file as a DWG and try to open it in POWERCADD 7 the text is huge. What can I do to fix this??
3 REPLIES 3
Thomas Holm
Guess: Check the that the dwgunit is correct on both sides. Set the scale on the PowerCadd side to the same as you had in Archicad.
I tried that and I still have same problem. Any other suggestions.
Thomas Holm
You could check your DWG with some other DWG-reading program (like Autocad) to determine where the blame lies. There are free DWG readers on MacOSX. (Do a search in this forum) But you could check it by opening ti in Archicad too!
I have a feeling this is a Powercadd issue. If the drawing unit and the scale is set similarly on both sides, I've never heard of a text sizing problem in DWG conversionbetween Autocad and Archicad.
