Archicad 17 to AutoCad 2014 block/object colaboration
I've been having problems collaborating with Autocad users in a project i'm doing recently.
As we are both working with the same 2D files there is a lot of DWG-PLN-DWG-PLN-DWG communication.
The problem is that when the AutoCad user opens my dwg translated file all de objects are with "weird" scales and not the same as I've moved/edit them in AC.
Does anyone have a clue why this happens or what can I change in the translation settings to avoid this?
cheers
SB
0 REPLIES 0
