Archicad 24 won't let me export any views to DWG
Lintel Studio
I'm trying to export some views into dwg and my file is simply not letting me do that.
Wondering if you can please shed some light on what can I do ?
I have tried restarting, updating, etc and it will just keep prompting the 'failed' X.
Any other format is fine but dwg which is what I need is not working.
Please help
Lintel Studio
I found the xref fix however the X now becomes the ! warning symbol.
Any clues as to what happens when that is shown?
Eduardo Rolon
Just to sum up. There are 2 ways to "export" to DWG one is to do a "Save As" (Individually) from the View and the other is to Publish (Multiple Sheets). Also there are 2 items that we can "Export" and those are "Views" (Individual Drawings) or "Layouts" (Sheets with Multiple Views).
In this case I would try to do a simple "Save As…" to DWG and choose any of the predefined Translators to see what mistake you get, post the screenshot so we can help troubleshoot. If that works ok then try a Publish (using a predefined Translator) and take a screenshot of the mistake.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
