2007-03-27 09:36 AM
2007-03-27 10:08 AM
2007-03-28 09:36 AM
2007-03-29 12:28 PM
Fabrizio wrote:Yes, that will be great but its not a 100 % solution becouse GDL limitations.
good suggestion Necko!
Changing the software itself could be just a bit difficult because actually we are busy in the porting for ArchiCAD 10.
Do you think it could be "acceptable" if the other materials could be set in the standard ArchiCAD Tool object?
I mean, in the main ArchiForma tool settings dialog window you set the "main" material then you can select the placed object and set the other materials by double-clicking in the ArchiCAD object settings dialog window.
Of course I can implement this feature only on those tool that use GDL statement which allow multi-materials.
Please, let me know...
Friendly
Fabrizio
2007-04-04 01:21 PM
2007-04-04 06:16 PM
