‎2022-05-10 07:53 PM
Hello, we are new to using the BIMcloud Basic Server and we have several projects that are now completed. We would like to remove those projects from our Teamwork list and the BIMcloud server and just have the project saved on our normal project server. I can not find anything in the help documents that walks me through the best way to archive a project so we have it saved on our office server and to remove it from our BIMcloud server. Any help would be appreciated.
Solved! Go to Solution.
‎2022-05-11 04:51 AM
At each milestone, backup your model and linked files to a conventional file folder system on your server. This includes re-pathing the BIMcloud libraries to linked libraries. Note that a PLN saved from a Teamworked model will still look for versions of the libraries that are hosted on the BIMcloud server. But you need to have the master copy of these BIMcloud libraries in conventional file directory format on your own file server and these are the ones that the PLNs should be referencing.
I hope this helps.
I hope this helps.
‎2022-06-09 03:25 PM
i'm also facing the same problem, that my computer hosting the BIMcloud basic is not almost out of storage. I want to move the whole BIMcloud basic to another computer.
@Ransom Ratcliff wrote:At each milestone, backup your model and linked files to a conventional file folder system on your server. This includes re-pathing the BIMcloud libraries to linked libraries. Note that a PLN saved from a Teamworked model will still look for versions of the libraries that are hosted on the BIMcloud server. But you need to have the master copy of these BIMcloud libraries in conventional file directory format on your own file server and these are the ones that the PLNs should be referencing.
I hope this helps.
What are your exact steps?
Also, does Graphisoft have an official recommended way to do it?
‎2022-06-13 10:47 PM
IMHO, the best method for migrating BIMcloud Basic Server and its Teamwork projects from one server machine to another is to save all the projects as a solo (PLN) in the projects’ conventional directory on your File Server, and then re-share those solo projects to the new BIMcloud. (BTW, any version migration or library repairs, etc. should be done while the project is in PLN format, before re-sharing it as a new teamwork project. This is a good time to clean up your Embedded Library of any duplicates and unnecessary bloat.)
But before you re-share the solo project, you need:
For background information, see Archicad Help on:
Save Local Copy of Teamwork Project
Join or Leave a Teamwork Project
Library Manager,
BIMcloud Libraries
Linked Libraries
Remove Library from Project
Teamwork Setup/Preparation
