AutoCAD 2004 & export from ArchiCAD 8.1 section\elevatio
Problem #1:
AutoCAD 2004 is not response if you will open section\elevation exporting from ArchiCAD 8.1 R2 RUS.
This file is save with 1:1 scale. I attach problem file: sec_scale_1-1.DWG.
Problem #2:
If you change scale to 1:100, file is open (sec_scale_1-100.DWG). But I cann't switch off cut fills of section.
Can you help me?
I work on Win2000 RUS SP4, IE 6.0 RUS
Only AC9 will export to AutoCad2004...
Best to export as 2000 from AC8+
It's not matter in that case: I am opening DWG-file what had been saved in 2000-format. AutoCAD 2004 can open 2000-format.
ArchiCAD 9.0.0 beta 10 INT (1683) equivalently...
stefan
Your drawing is only 12 kB. That's rather small and indicates that there is probably not much info contained in it...
Archicad28/Revit2024/Rhino8/Solibri/Zoom
Archicad-user since 1998
my Archicad Book
