archicadallthetime
BIMCloud saas and BIM360
Hii all,
Recently I have had a challenge where there is a project and the owner as well as the other stakeholders are on Revit and BIM360.
I don't want to either jump to revit or BIM360 where I am forced to change my workflow.
Quite comfortable with BIMCloud saas and Teamwork.
My question is they showed me something on BIM360 which is an important feature.
You can open and view the file inside of BIM360. Eg : open a pdf and view it inside BIM360 and also comment on it.
Also .rvt file or .ifc can be opened and viewed inside of BIM360 and can even do the comparison based on the design versions.
I know all this can be done inside of Archicad, but I cannot force them to use Archicad.
Is there any possibility using BIMCloud API where what all BIM30 can do even BIMCloud SaaS can ?
If anyone is facing the same issue please comment how are you tackling it.
0 Replies 0
