Cadimage bracing
Are any of the Kiwi users here using the bracing tool?
Have you been able to use it for subfloor bracing lately?
I used to use it up until last year some time, but it has had some issues which supposedly have now been fixed, but I still cannot get it to work, it seems to have a problem with the fixed BU's over 120.
I have been onto tech support several times in the last year, but they just keep saying it wasnt designed for subfloor bracing.
If anyone is using it for this can you please tell me how you are doing it.
1 REPLY 1
After a lot of playing around with it, I found the answer!
Put a tick in the "Engineer designed" box but then click on the edit brace type.
That does the trick!
