Cadimage - wall framing & ArchiCAD 13
Hello!
I have archiCAD 13 x64 and cadimage. I would like to try wall framing, but I think I have some problem or I just don't now what I'm doing wrong.
I wached video on cadimageworld.com:
http://cadimageworld.com/support/viewmovie/771-attachtoacomposite
But when I open Element atributes/Composite structures I don't have a option wall framing..
What's the reason? Please, somebody help me ...
3 REPLIES 3
Brett Brown
You have to add the wall framing option in your work enviroment
Imac, Big Sur AC 20 NZ, AC 25 Solo UKI,
Thank's for answering! But how can I get this option, what I need to do?
It should be added when you install the program. Do you have a Cadimage menu? If not you would add it in the Work Environment settings (Option menu).
The framing add-on requires a bit of careful setup even if all you want to do is use the included presets. I suggest reading the documents carefully and following the instructions step by step or you are likely to have a frustrating experience.
