Ci Keynotes palette opens with file in AC27
tjmillar
Ci Keynotes is part of the Select Agreement now, automatically included with our license. The keynote palette opens automatically every time I open a file in 27. We don't use keynotes. How do I turn off the automatic opening of the palette?
AC26 Australia, Windows 10
I would assume you have to uninstall the CI Tools add-on, or at least the keynotes part of it.
Probably best to contact Central Innovation to see if just Keynotes can be turned off.
I have the same select agreement with CI but have never installed their tools so I don't see any keynotes.
Thanks Barry.
CI advised that there's no way to stop the auto-open of the palette, the only way is to uninstall the tool.
Even if I used the tool though, I wouldn't want that palette open all the time. I don't think it's a good choice by Ci to make the tool behave that way.
MASz
As Barry Kelly pointed out, your question is better directed towards Central Innovation rather than the Graphisoft forums.
However, I will point out this is actually a bug. It should already be fixed in the latest update of CI Keynotes.
AC27 AUS, Windows 11, i9-13900KF, RTX3090, 128GB DDR5, 4k144 display
Setup info provided by author
