Fabrizio Diodati
Graphisoft Alumni
Graphisoft Alumni
Cigraph compatibility updates for ArchiCAD 11
Dear users,
I just want to notify you that the Cigraph plug-ins compatibility upgrades for ArchiCAD 11 are ready for the download.
The following plug-ins are now compatible with ArchiCAD 11:
ArchiFacade
ArchiForma 2
ArchiMap
ArchiPanel
ArchiRuler 2
ArchiSketchy
ArchiStair
ArchiTabula
ArchiTerra 3
ArchiTiles
ArchiTime
ArchiWall 2
The following plug-ins, instead, don’t have an ArchiCAD 11 compatible version:
ArchiForma 1
ArchiRuler 1
ArchiTerra 1
ArchiTerra 2
ArchiWall 1
ArchiPaint (it has been dismissed)
As I already wrote in this forum, for several reasons, the compatibility updates for ArchiCAD 11 are not free of charge: any update costs 15 Euro.
If you are a Cigraph users and you want to update your add-ons for ArchiCAD 11 you should buy these compatibility updates from www.cigraph.com
In this way you will get a new Registration ID that let you unlock the add-on for ArchiCAD 11 (that is downloadable from the same web site).
Once you unlocked this latest version, the previous one (that ones for ArchiCAD 10 or ArchiCAD 9 or ArchiCAD 8.x) won’t work anymore: just because you changed the unlock code.
In order to use the add-ons also with the previous versions, you simply need to download and install the latest updates for AC 8, AC 9 and AC 10 (also these ones are downloadable from www.cigraph.com) . These latest updates works both with the new and the old unlock codes.
If you don’t buy a compatibility update for ArchiCAD 11 you don’t need to download these latest updates: they don’t include any improvement or bug fixing: the only difference is that they handle both the new and the old unlock codes… but, on the other hand, all these versions include a new update checking procedure (automatically or manually performed) that will let you update about our products.
Friendly
Fabrizio
Fabrizio Diodati
Graphisoft Italy Srl | Via Rossignago 2/A Spinea Venezia 30038 Italy
0 Replies 0
