‎2007-06-07 05:16 PM
‎2007-06-07 05:38 PM
‎2007-06-07 06:24 PM
TomWaltz wrote:This is what I've done.
I actually re-scripted the set of doors we use to have a parameter that is formatted correctly that the scheduler can read.
TomWaltz wrote:Well, as long as I've been on the forum, anyway: VOTE
It's been a wishlist item for as long as I can remember,
‎2007-06-07 06:46 PM
‎2007-06-07 06:51 PM
max wrote:It's as easy as adding a parameter to the list them doing a little STR work in the Parameters script. The annoying part is that you have to do it to every door object.
is there a simple way to re-script doors and windows to do that? do they have to be archicad doors and windows? i ask this because some of the doors and windows we use are through the door and window builder 35 program, so i don't know what the scripting options are on that.
it's not a huge deal, but as i said, if there's a simple method to do so, it would be nice to know it.
thanks.
‎2007-06-07 06:52 PM
max wrote:Unfortunately, you can't edit the scripts of the DWB objects, so it's not possible (this is one reason why we don't use the Door portion of this add-on).
... some of the doors and windows we use are through the door and window builder 35 program, so i don't know what the scripting options are on that.
‎2007-06-07 07:02 PM
‎2007-06-07 07:58 PM
‎2007-06-07 08:07 PM
Laura wrote:Also, I don't think door and window builder is compatible with the interactive scheduler in archicad...seems like you need to use their provided list routine to schedule doors and windows. Can someone who knows please comment on this?max wrote:
...Unfortunately, you can't edit the scripts of the DWB objects, so it's not possible (this is one reason why we don't use the Door portion of this add-on)...
‎2007-06-07 08:48 PM
Dan wrote:Actually -- yes, this is true -- but if you
