Colors in point cloud?
Mats_Knutsson
I'm doing my 2nd point cloud and this time I can't get any color in the point cloud model. All black. Any ideas? The screen shot is AC20 and Adesk Recap.
Mats
AC 25 SWE Full
4 REPLIES 4
Check out these two clips and see if they help you find the answer to your question:
https://www.youtube.com/watch?v=g1O3stCc7TM&list=PLnXY6vLUwlWWW2G9Ve7MxoLW2tZ9TWFMW&index=3
https://www.youtube.com/watch?v=gWw3BwXPXzU&list=PLnXY6vLUwlWWW2G9Ve7MxoLW2tZ9TWFMW&index=4
Mats_Knutsson
Thanks for the links. I browsed the INternet yeterday and found several post in this issue and it's e57+ArchiCAD that's the problem. I'll see if the measuring guys can send xyz instead. I use Recap for slicing the big model and it's working fine but I cant figure out if it can export xyz.
AC 25 SWE Full
There is a free Point Cloud processing software called CloudCompare using which you can do a lot of things with your Point Clouds, hopefully also convert between formats:
http://archicad-talk.graphisoft.com/viewtopic.php?t=54196
Mats_Knutsson
I got an xyz and it worked great! Would also like e57 to work the same way. I'll take CloudComapre for a test as a cenversion tool.
AC 25 SWE Full
