Column schedules
I have created a profiled metal sheet as a column and I need to create a schedule that would show these metal sheets - specifically the 2d section-cut.
My problem is that I can't get nor the 2d, nor the 3d views for the column.
Does anyone have any solutions for this?
1 REPLY 1
Objects had the 2D and 3D views in schedules. so you may try to save that columns as OBJECTS (with diferent names if they are not same)!
