Column schedules
I have created a profiled metal sheet as a column and I need to create a schedule that would show these metal sheets - specifically the 2d section-cut.
My problem is that I can't get nor the 2d, nor the 3d views for the column.
Does anyone have any solutions for this?
Objects had the 2D and 3D views in schedules. so you may try to save that columns as OBJECTS (with diferent names if they are not same)!
