‎2010-04-19 08:29 PM
‎2011-01-11 06:29 PM
‎2011-01-11 07:29 PM
Catalin wrote:You can open the DWG drawing as a library part and it will create the 3D GDL for the lines and fills. It does not convert text so the grid IDs will not come through and the lines will not be individually detectable. The only hotspots will be on the bounding box.
It's possibe to see the grid lines in 3D dwg file?
‎2011-01-11 08:29 PM
Matthew wrote:Sorry I was asking the other way, Archicad grid lines exported from 3D windows as a DWG. When I export in dwg i have only the text without the lines.Catalin wrote:You can open the DWG drawing as a library part and it will create the 3D GDL for the lines and fills. It does not convert text so the grid IDs will not come through and the lines will not be individually detectable. The only hotspots will be on the bounding box.
‎2013-12-06 02:58 PM
