DXF file Text showing as ??? Help Please!
I posted this yesterday but no-one had a response, so I ask again:
In AC9 when I import DXF files all the text shows as ????. I am on Mac platform, my reseller tried it on Window platform the same file with out any problem and Tech Support does not return the call. I am using the default translator. Apparently the fonts are txt.shx that are in the files, even when I do not say skip and point to this font I still get the ???? in place of text. DWG files translate the fonts properly. Did not have this problem in AC8.1. Have two separate copies of AC9 on my Mac and both have the same behavior.
Thanks,
Joseph harouni
1 REPLY 1
Well Finally got in-touch with Tech Support, IT IS A BUG IN AC9 in Mac only. I am not a happy camper, so we have to wait for AC( v1.
Joseph
