Door rotation left or right
I want to show the door rotation. Is therefor an option? Left or right rotated?
10 Replies 10
Ralph Wessel
jkiox wrote:
Now, is there a way that I can set the Front View as a fixed view where this could be the opening side or the opposite of the opening side.
You could try using the Modular Joinery object. It has been developed for UK subscribers, but is freely available from other distributors/resellers around the world. This object supports any number of doors/windows/panels within the same frame, and therefore you have full control of opening direction (in/out/left/right) irrespective of the original placement position. In the attached image, I have created 4 doors in a single frame to illustrate possible orientations. You could use these settings to enforce the output required in the schedule.
Ralph Wessel BArch
Central Innovation
