EXPRESSION - Plan impression
Hello to everyone,
I wanted to ask you if there is any possibility to put two automatic text of drawing scale:
1- One for the drawing in the original sheet size (in this case A1 sheet).
2- Another for a possible print on A3.
¿Is it possible with expressions to divide an scale? Like the original size / 2: 1:50 / 2 = 1:100? I attached an example of our label where it puts "Escala A1" (scale) and "Escala A3" it should appear 1:50, 1:100 respectively.
Best regards,
Fran.
1 Reply 1
The example did not get attached. Can you attach it?
