Errors in energy model
Hi, I am trying to use the archicad as a modelling tool for gbxml export but I have a problem:
When the walls touch in T shape then there are holes in energy model: Any way to solve this?
1 Reply 1
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Thank you for sharing this question!
Although I'm not an expert in this field, let me understand your question first before forwarding it to our team for further investigation: if all zones (room) in this model is assigned to a thermal block, should the hole at the joint of T shape walls be covered?
Furthermore, could you share with us an example file where this issue is presented for a closer look? Let me know if you need a secure link to send the file also!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
