2024-05-16 03:36 PM
is it possible to export IFC translation settings or only import them?
I have IFC translation settings prepared as TPL file that I can import, but don´t know how was it made or exported from Archicad.
Anyone know or can link me
Operating system used: Windows 11 Pro 23H2
Solved! Go to Solution.
2024-05-16 04:01 PM - edited 2024-05-16 04:02 PM
It's not possible to export only IFC translators. Save the file containing the IFC translators you need normally as Archicad project (.pln) or template file (.tpl) using File → Save as. You can then import the translators to a different project from the saved file. You could also create a new empty file using a template, import the translators you want and then save the file as .pln or .tpl.
