Export IFC and DXF file to ETABS
Roopa A
What are the settings to be done to export to ETABS using DXF and IFC file format.
I tried the setting in DXF-DWG Translation setup and IFC Translation setup.
The file is not opening in ETABS.
Please help me.
Thank you,
Regards,
Roopa A
Roopa A S
32 REPLIES 32
Roopa A
It is not attaching the file, both IFC and pln file?
Roopa A S
The best PLN
At worst IFC (IFC'll be more lightweight)
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
Roopa A
It is showing invalid file extension for DXF, IFC and pln file format.
Roopa A S
What about your OS and Archicad ?
There is something wrong about your installation
Christophe - FRANCE
You can't attach IFC or PLN files directly in this forum.
You must ZIP them, but then they may still be too big.
Use a file sharing utility (like Dropbox) and private message the link to Christophe (or post it here if you don't mind everyone else having access).
Roopa A
Sir Check the file please. This file is created just for checking weather it is opening in ETABS or not.
ArchiCAD file is attached.
Thank you,
Roopa A S
Hi
No matter to export an ifc
No matter to read it with SMV (Solibri)
All the element seems to be right...
I've not found a ETABS for macOS to check this ifc
Christophe - FRANCE
Roopa A
But, Its not working for me. Do you changed the units or any settings.
Thank you
Roopa A S
No I do not change anything
Perhaps it is more an ETABS parameter issue
Christophe - FRANCE
Roopa A
I am having ETABS 9 version. Is this is the problem.
Thank you
Roopa A S
