Export format
krab-El
I want to export my Layout to dwg file but there is only the pdf format option. Could you please help me solve this issue?
Thanks
David Maudlin
krab-El:
Select the Publisher Set (up one level), then click the Publishing Properties... button and select either Create a real folder structure or Create flat file structure, not Create a single file.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
krab-El:
Great. Thx
