Export to 3ds - strange surfaces
Mats_Knutsson
Mentor
We're exporting 3ds from AC to 3DS using materials, scale=1000mm. When opening the 3ds-file in 3DS the surface textures lok weird and flickers when moving around. If I move closer it looks ok but when viewing the whole projects it looks really bad. WE get this from Sketchup as well.
Is there any solution to this?
See attachment for visual explanation.
Mats
AC 25 SWE Full
4 REPLIES 4
Fran_ois Chatelain
Hi Mats,
try setting your units to 1mm.
Cheers
Francois
FranƧois Chatelain
Worldwide Digital Imaging
Formerly posting as RanXerox
"A little bump will help blur your reflections"
Mats_Knutsson
Mentor
FranƧois wrote:
Hi Mats,
Cheers
Francois
Do you mean in the export? I tried and the flickering in 3ds was gone but the scale was of course wrong. We need to work in the correct scale. We'll install a new really strong graphics card and see what happens. we've had it for two weeks but it's still in the box.
Salut,
Mats
AC 25 SWE Full
You might try changing both export and import units. This would retain the scale and might help the textures. How do they render? Is it just an OpenGL problem?
You may already know this, but another thing to watch out for if you are importing multiple 3DS files is that the SketchUp exporter will duplicate texture names which will completely mess up the material assignments. The only fix I've found is to rename the textures before importing them. The importer will then ask you to relocate the "missing" textures. It seems really stupid that SketchUp does this but I guess they haven't though it through.
Mats_Knutsson
Mentor
Thanks, we'll try that. It's mot likely an OpenGL problem. It's a single 3DS-model from ArchiCAD. /Mats
AC 25 SWE Full
