2011-03-14 08:07 AM
2011-03-14 04:23 PM
durriken wrote:I'd be hesitant to use this approach. In theory, this could work well. The main problem is compliance with the schema - I don't think it's open/published. Most of it can easily be deduced, but the there are some aspects that might present serious obstacles.
I'm writing an export script to export models from a 3D modeling software to ArchiCAD's XML GDL (which I then convert to .gsm with LP_XMLConverter) format and I got a few problems.
I guess I'm doing something the XML format wasn't meant for..
2011-03-15 07:34 AM
Ralph wrote:Yes it does seem so. The LP_XMLConverter's documentation has some information about the format (dtd and XML-schema) but it doesn't really explain everything I need.durriken wrote:I'd be hesitant to use this approach. In theory, this could work well. The main problem is compliance with the schema - I don't think it's open/published. Most of it can easily be deduced, but the there are some aspects that might present serious obstacles.
